avermedia homefree combo inputs
ramkris
I am planning to get this to watch tv wirelessly across home. I wanted to know if the HD tuner works in India. This has both an analog and digital tuner. It is based on DVB-T. Will it pickup digital signals from the cable settop box? My cable box does not have any card for authentication I guess, ideally it should work, doesnt it?
http://www.flipkart.com/avermedia-h...-4573a2c21c8e&srno=m_1_1&otracker=from-search
There is another product without the digital tuner and composite inputs which come for 1500 less.
http://www.flipkart.com/avermedia-h...id=reco_pp_same_tv_tuner_card_tv_tuner_card_2
Unless I get full functionality its wise to spend less and get the class product isnt it.
If anyone has tried this, please advice.
Avermedia Home Free Combo (F210) | Tv Tuner Card | Flipkart.com
Most of our Indian based digital broadcasts are encrypted which can be read only by the specified/respective providers set top boxes. It cannot be decoded by other digital boxes. I think with the above boxes that you have mentioned only the Doordarshan based feed can be read which are actually free to air services/channels.
Since my cable box works even without the cable card inserted, I expected the broadcast in unencrypted. I will further look at the cable box to identify the protocol. Its an sradix box given by incable in bangalore.
