AVR for Jamo speakers
vb86
New Delhi
Hi guys!
This is my first post on this forum! My bedroom setup is as follows:
Center speaker: Jamo A10 CEN
System Type 2-way closed shielded
Woofer (mm/in) 76 / 3
Tweeter (mm/in) 19 / ¾
Power (W, long/short term) 60 / 80
Sensitivity (dB, 2.8V/1m) 86
Frequency Range (Hz) 150 - 20,000
Impedence (Ohm) 6
Weight (kg/lb) 1.1 / 2.4
Front Speakers: Jamo A102
Impedence (Ohm) 6
Weight (kg/lb) 0.7 / 1.5
Surround Speakers: Jamo A10 SUR
System Type Fullrange closed
Frequency Range (Hz) 150 - 15,000
Impedence (Ohm) 6
Subwoofer: Jamo SUB 200
System Type Sub
Woofer (mm/in) 203/8
Frequency Range (Hz) 36-150
Impedence (Ohm) 22K
Weight (kg/lb) 8.4/18.5
I actually bought the HTIB solution called Jamo A102 HCS 11 which came with the Jamo DMR-61 amp cum dvd player.
Unfortunately, I'm unable to furnish the specs for DMR-61 as the Jamo website seems to have removed them.
Now, I want to remove the DMR-61 and get a proper AVR for this setup. I have shortlisted the following 3 AVRs:
Denon X2000
Pioneer VSX-1123-K
Yamaha RX-V675
Some notes:
1. As far as room calibration goes, Denon uses Audyssey MultiEQ XT, Yamaha uses YPAO PLUS RSC and Pioneer uses MCACC. I hear that Audyssey can calibrate the sub while the others can't. Also, MCACC can save 6 positions. How does YPAO fare?
2. If Denon is the way to go, does it matter if the importer is Kripa or ProFX? I'm based in Delhi.
3. The Pioneer specs seem to vary from the US model. I checked the output and it seems different? Is this true for Yamaha and Denon also?
4. Airplay is present in all 3. I need Airplay, but built in Wifi and Bluetooth would be a plus!
5. As far as sound quality is conceded, which would be the best?
6. How is the after sales service for these brands in Delhi?
7. Devices to be connected - PS3, TS+ HD box, WDTV (soon to be replaced by an HTPC)
Is there anything specific that I should be looking at in terms of specs and features?
Lastly, if you do have any other recommendations please let me know!
I have listened Jamo with Marantz, IMHO it sounded great, would suggest to consider this brand as well.
