aurobindosaha
Not sure about casting to CCA, however Bubbleupnp can cast YouTube audio to RaspberryPiwhich app is that, stream youtube to CCA?
How good is the optical out of chromecast audio?This is kind of mini review or consultation thread after extensive use of Google Chrome Cast Audio in various way with various cables.
About 8 months ago, under this thread (https://www.hifivision.com/threads/chrome-cast-audio.67923/#post-747758) some of us discussed about CCA, I was not satisfied with it's analog out, rather I used it's optical out. But this cable have changed the analog out drastically. Low and Mid was already good with CCA, especially mid was vanishingly artifact free. Many hifi DAC sounds ear fatiguing even through mids, but not the CCA. It is easy sounding without being warm. Main problem with the CCA is the High Frequency which is kind of restricted sounding with the stock cable and also with many hifi branded cable. Canare L-4E6S gave (bought from ghent audio - http://www.ghentaudio.com/part/d11.html or http://www.ghentaudio.com/part/b01.html) a big relief on that restriction. Highly recommended for Google CCA.
Now I only use the analog out as I feel it's analog is superior than optical out with external DAC. Any cable non-believer person can test this cable and see how this canare cable change the expression of a device. I find many of us are selling their CCA, I like to request them to use the referred cable before giving up the CCA. Their might be better cables but those will cost much much more.
Depends on your DAC.How good is the optical out of chromecast audio?
Raghu
Hi Newlash. Are you sure? Becuase I am using my Sony Android TV's optical out to feed my DAC & playing Tidal music by casting from my phone to my Sony Android TV. The sound of my TV's optical out is horrible. So thats why asked if cromecast audio also has the same issue.The optical out is excellent. In fact optical is the best connection possible if you are looking at bandwidth below 24/96. Optical does not have the EMI /RF problems that coax and usb have. Get a good cable and enjoy your music
Chromecast puck is an add-on for rigs that don't it.Is it still worth buying chromecast if my receiver has one built in? Many pioneer receivers have built in chromecast.
Also using the heos app we use wifi to stream music (amazon music). In such scenario will getting chromecast audio be of any use?
I'm in the US. Nevertheless I've ordered tubes from global eBay sellers while in India and received them just fine.Seems u are using ge tubes where to buy them in india??
Thank you so much newlash for helping me out with my query. I am ordering CCA right away.Hi harsh...
Probably this particular television has a poor digital to optical convertor or there could be too much electrical noise getting into the digital to optical convertor. This is usually the problem when there is a lot of power intensive processing going on inside. However the CCA has been designed ground up just to deliver audio, and nothing else. And I find it's optical out to be excellent. Iam using an audio quest cinnamon mini optical cable I got from UK. And iam finding the sound pristine
Are they still available in market?.I am ordering CCA right away
Will have to seach a little bit. But not hard to find.Are they still available in market?.
