BenQ 1070 color smudging problem after 2600 hours
vij
hyderabad
My 2.5 year old benq 1070 is now producing horrible smudges and saturation in bright and dark scenes. Its ok in moderately lit scenes.
Its run about 2,600 hours in normal mode. Could it be color wheel or just the lamp dying? Pic attached
when was the last time you got it serviced? Mine kept shutting down after 4 to 5 minutes.
when i called the service center, they said the bulb should give atleast another 2 to 3000 hours. He cleaned it thoroughly and bam it was as good as new.dust accumulated in the sensor for the wheel was causing the flicker and shut down.
it could be a problem with bd player also. I had a similar problem with colour. problem was with the hdmi port of the bd player. You need to identifiy the cause.
