best 5.1 0r 7.1 home theatre system under 25000
charan89
india
Hello all,
I was planning to buy LG/Samsung LED 42" tv.
To complement the same, I'm planning to buy floorshaking home theatre.
I searched through Google n got to know about Edifier s550.
Can you guys help me out with this?
Im a bass lover. And what about getting 2big speakers assembled.
Thanks in advance :)
The main thing for you is to go window shopping and audition as many brands as possible. Home Theatre in a Box (HTiBs) like Sony / Samsung / Panasonic / Philips will not be able to give you floor vibrating bass which you want.....professional entry level home theatres start from 25k onwards (Yamaha/Pioneer / Onkyo / Denon etc.) and can go upto lakhs....sky is the limit.
Depending on your room size, first decide what kind of speakers you want...satellites / bookshelf / towers....then sub yes or no...given that you want bass more...sub would be mandatory.....
Would suggest you take your kind of music and audition as many systems as possible and see which meet your requirements in performance , connectivity and ofcourse...fits your budget....you may need to spend a bit more based on your requirement...
For starters you can buy a decent AVR (5.1 amp) and a pair of towers / bookshelf speakers..later when budget permits, purchase the surrounds, subwoofer and centre speaker....
If you are open to owning pre owned equipment, please check out the 'Sale by Owner' section of this website or refer to HiFi Ads or other online classified websites...you may get lucky and get an excellent system for a bargain....all the best!
http://www.hifivision.com/home-theater/22879-jbl-cinesystem-140bk.html
Check this out .. Thsee speakers sound great and the best in the price range. Compared to onkyo I think within this bug et this is the only package with an active down-firing subwoofer and it just great .I have had it for a very brief period. Satellites are small yet sounds great.but the subwoofer is the best part and you like bass ..so just give it a try .
