Best matching tower speaker for Denon Avr X1000 below 50k.
triumph
bangalore
I need your expert advice regarding the best tower speakers below 50k which matches well for my Denon Avr x1000. If somebody could rate it would be very nice. My purpose is mainly music , occasionally movies.
You need to keep a few things in mind before purchasing the right set of speakers.
Firstly the impedance should be the same or more than the AVR / Amplifier, this will ensure minimal stress on the power section.
Secondly, you need to ensure that the speakers you select can perform across all frequencies between 20hz to 20khz. Typically Tower speakers starts from 35/40hz till 20-23khz. The maximum spectrum of frequencies provides, the better delivery.
Next is the cone size of the speakers. The bigger it is the better throw and frequencies emitted.
You need to check the output specs of the X1000 and accordingly purchase speakers which have the same output or more. Do not look at the peak power output.
Here are a few recommendations, Bostons and Wharfedale work well for music and movies. You may want to add a subwoofer later to get that depth and punch for movies and music.
Boston Acoustics A 250 Floorstanding Speaker
Boston Acoustics A 360 Floorstanding Speaker
Wharfedale DIAMOND 10.4
Sonodyne also has some good towers
Sonodyne Sonus 2605 V3 Floorstanding Loudspeaker
Sonodyne Sonus 2504 V3 Floorstanding Loudspeaker
There are other brands like Jamo or Yamaha or B&W in the market. It all depends on the size, what appeals to you in performance, quality etc. Polk has the RTi series which you may want to consider. The key is to audition as many towers as you can and if possible carry your AVR as ultimately you will be connecting the shortlisted selected towers to it. Also your decision is based on the fixed budget you have. Check with multiple dealers for the best price and warranty.
All the best, hope this helps.
Auditioning is my biggest problem. My profession and my current location are like that. I had only auditioned Kef and Polk in pro FX. Don't think I'll ever get time for more. Also I am craving to listen to some good music after my work. I liked the punch in tsx 440 but it lacked the clarity and distinction of sounds which Kef had at highs. Mids and lows should be really good for the speakers of my choice. How do you rate Polk tsx and rti ?
The best speakers to go with a Denon AVR would be the ones that sound good to you. You will have to go and audition the different brands at a store.
I use Polk Audio with my Denon 2313 and am pretty happy with the output. They would even fit your budgetary requirements. A set of TSx440T floor standing speakers will cost you about 35k INR.
Hi triumph
ProFx uses Denon AVRs to provide auditions for Polk or KEF speakers in their showrooms. Based on your budget and requirements, you can visit and do a quick audition and decide speakers which appeal to you.
Heard that ProFX is changing from Denon AVRs to Pioneer and this has happened in some stores.
TSx series are within budget and RTi series costs more. ProFX regardless provides a 10% minimum discount and you should demand for it.
It would be better to carry your own music CDs or pen drive to decide which speakers will suit you as at the end of the day, you will be hearing your kind of music. Polk is backed with 3 years warranty unlike most other speaker brands.
Thanks guys. I bought Polk tsx 440 FS and tsx 250C . Currently a 3.0 setup. Donno whether my Denon x1000 has enough Mojo to run it
Hi triumph
The sensitivity of the speakers are high and hence you will get good output from the speakers.. Congrats on your new setup.
congrats and enjoy.
me also heard tsx 440 there.They played beautifully without sub.
Between how much tsx 250c cost you?
regards
girish:)
I am looking to sell my polk tsx 440t , only 2 months old. Please refer to anybody from delhi ncr who would like to buy it. Bought it from metropolitan mall ggn with proper bill & warranty. Speakers are nice but i am looking to upgrade to rti series. 9818195508
