Best Media Player to play MKV
Pratters
Calcutta
I have used the WD TV for a while but it has an mkv problem and can't play many of the latest mkv files.
I am looking for a cheap media player to play mkvs over my 104" screen.
Please suggest. One which has updates would be preferable as I don't want my player to become outdated like WD TV.
They have stopped updating WD TV ages ago. It needs a simple update but they won't do it. Shows the company in very bad light. There is a work around but it is pretty irritating, so I am looking for a new permanent solution.
So which would be the player you guys would suggest for playing mkvs flawlessly which also has updates?
i have been using Xtreamer for a long time and never faced an issue with firmware updates. They have always been there. Would recommend to try out the same as it is a good product.
