Best option in LCD/LED below 40K for 32'' - Pl help
bidhu77
Ambala
I am not able decide on which 32'' lcd/led tv to buy below 40K.
My viewing distance is about 10ft. I have noted some models.
1. Panasonic Viera L32U20 FHD LCD - 30500
2. LG 32LE5300 HD Ready LED - 36000
3. LG 32LE5500 FHD LED - 44000 (If too good I may expand my budget)
4. SAMSUNG 32C4000 HD Ready LED - 37000
5. SAMSUNG 32C5000 FHD LED - 41000
Is it worth spending extra bucks for 32'' LED or I should go for the LCD.
Again Full HD LCD or HD Ready LED ?
Which brand ?
I have heard Panasonic is better than Sony, Samsung or LG.
Please guide me.
For a distance of 10 feet you may opt for a 40/42 incher. You may get Panasonic/LG plasma around 35K and incase you want to avoid plasma you may also have LCD options in LG/Samsung around 40-45K.
10 feet would be a little too big viewing distance for 32 inch lcd.
Well for that viewing distance a 32" tv will be small.
With a 40k budget you very few option in lcds in 40" segment,there are some HD ready plasmas.
For around 46k you may get a samsung 40C530.But if you willing to buy from grey market you can get 40" lcds from sony starting at around 36k.
I think you are right Peeyush. I need a bigger screen. According to you if I want to remain below 40K then I should go for 40/42'' LG/Samsung Plasma. Could you name few good models from these and their best prices ?
thanks adder. do you have any idea from where can i get sony tvs in grey in delhi. can anybody suggest some places for buying grey in delhi ?
