Best speakers to audition with denon 2310.
bobgalee
India
Hi friends,
I am from Chennai.
I have decided on Denon 2310 as my AVR. My budget is 40k
I want to build my system gradually due to budget constraints. Starting from 2.0
Kindly suggest some possible combinations to audition
Please pour your valuable inputs for Best frontspeaker combos for auditioning with Denon 2310 (bookshelf or floorstanders which is preffered?)
Thanks a lot.
I want to start with 2.0 Speakers and then extend it gradually.
AVR might be around 35 to 40k. So I can extend for 20k for 2.0 speakers.
You may need to stretch beyond 40k for Denon 2310 alone. Based on your budget, I am a bit curious on why you chose 2310? In your budget range, 1610/1910 may be more apt, think about it.
you could start with a pair of bookshelves. and then add on sub, centre and surrounds later. look at wharfedale diamonds, monitor audio bronze and kef iq series
20k? Usher S520, from the bunch that I've heard in this budget this speaker is in a different league. An overachiever if there ever was one.
Well 2310 is for 62k around & for said budget,1910(40k+) for AVR only.
For AVR + SPK ,1610(30k) + 15k for spk.
thanks for reply friends.
then for the AVR 1910, kindly suggest good speakers to audition.
I want to build the system from scratch. (2.0 to 5.0 then later to 7.1)
thank you.
thank you.
With 1910,
2.0 spk can be MA BR2 (good for music & mov) may be for 25k.
Wharf 9.1 for 14k, Tannoy F1 for 16k
If need 5.1 you can lator add Centre surr lator.
Complete package can be Kef2005 (70k?) 3005(95k)
Qacoustic 1010i for 60k,Jamo pack can be around 45kless.
I know is heavy on budget,but good combo sounds better.
