Best speakerwire in AWG 16/14 for Home theatre connection
ucas
India
First i need to say HI to everybody as this is my first post in HIFI. Thanks for all your previous blogs, very useful.
I need to get very good speaker cable in AWG 14/16, please somebody advice.
This cable is for ONKYO HTS5100, Priced at 38K. which i had planned to purchase. If anybody has other good choices, please let me know.
Rgds
Ucas
I am using 16 awg for front,centre & 14 awg for surrounds.(from Taiwan)
All are O2 free.They are bought in loose.
Hi Pals,
Thanking you for the inputs....
spirovious - Have you got the wires in taiwan or in india, If in india may i know the info.
Muthuswami - May i know where you purchased it. Iam in bangalore
Thanks all...
Hi Pals,
Thanks all...
I bought the MX OFC cable from a authorised dealer in Ritchie street, Chennai.
Hi Pals,
Thanks all...
I got cable from Lamington Rd,Mumbai.
Price-
1. 16AWG- 50/mtr (5 months back)
2. 14AWG- 70/mtr
I found if you use thick cables than actually required, trebles becomes harsh.
So my Q is is there any formula to calculate cable thickness against speaker
distance from AVR for perfect sound Q?
I got few tables on web, but its general.
I also found if thiner,acurate cables is used ,you get perfect tonal Q.(related with distance)
eg.16 AWg for fronts upto say 5 mtr is perfect & you use 14Awg (thicker)
treble can dominates Bass.
What are your thoughts?
Are branded cables are realy worthy than local?
chord company,Qed spk cables are 500/m & Loacal-even imported loose cable
50/m.
Secondly what thickness branded cable offer?(viz 14,16 AWG)
