best to use hometheatre package
markyboy156
kettering
hi
if you was to choose
out of these speakers what would you choose in order of best to use for hometheatre and music
jbl 590 or
svs ultra towers or
or chane 2.4
or emotiva t2 or
monitor audio bronze 6 or
or kef r500
in what order thanks
i will be using a denon 4400
blue node 2 streamer
oppo 205
sky q
buzz tv box xls 3000
out of these speakers what would you choose in order of best to use for hometheatre and music. in what order thanks. i will be using a denon 4400
I would choose 7 (or) 11 identical speakers based on the ceiling, from any of the brands you have listed.. Identical speakers for seamless soundstage from front to back of your listening position, and may be go to extent of adding the same speakers on ceiling too for a near perfect experience..
I have fetish for JBL horns. So my first preference would be JBL studio 590. But the problem is that these are huge, and I really mean huge speakers and you need enough around them to let them perform at their best. Second disadvantage would be finding remaining JBL speakers, to make a multichannel system .
Just due to the above two reasons, I would go for the kef R500 :)
