Hi, I'm a noob to this forum, so please bear with me.
I had an older H/K AVR 132 / JBL SCS 200.5 setup.
Yesterday I upgraded the fronts to a pair of floorstanding Polk Audio TSi 400s (expecting delivery today).
Over the course of the next few months I'll upgrade the rest of my system in phases, starting with the receiver.
I had a few queries about bi-amping.
Bi-amping is basically pushing two channels' audio into different posts on the same towers so that the different drivers are driven by different receiver channels rather than the same, right?
So by that logic, if you have a 100W/Ch receiver, and you bi-amp it, you basically push 200W into your speaker: is this correct?
This would mean that your receiver should be less than half the rated capacity of your speakers, or you risk overloading it if you bi-amp, correct?
For eg: If I buy an Onkyo 616 (which is 100W/ ch) and bi-amp it to my Polks (which are 200W max. power), I risk driving my speakers at the saturation point, which is risky. So if I have to bi-amp, I have to buy say an Onkyo 515 that's 80W/ch which, when bi-amped will give 160W which is fine for speakers rated 200W.
Is my line of thought sensible? Or am I missing some major point here?
