Bluetooth headphones for movies on TV
Onri
Navi Mumbai
I need Bluetooth headphones to be used with TV mainly for movie experience, so sound quality is the primary requirement. Budget 5k. Any recommendations?
Again my recommendation will be a BT dongle that can connect and enable all hi res BT codecs like LDAC, APT HD (assuming your TV supports them). This will enable any iem earbud or HP to be used via BT.
Thanks for suggestion, any specific BT dongle that can enable most codecs you mentioned there?
You can't go wrong with either Fiio BTR5 or Shanling UP4/UP2. They have all the good codecs, but again all that depends on whether or not your device that you intend to connect to your BT dongle supports that codec.
Sorry for hijack this thread:-
Same preference for movies...watch at night times
How to check TV supports them? (Holding Mi Tv)
Which one is good for BTR5? Ear Phones or Head Phones?
