Bookshelves and Center Speaker from US for India?
Marantz is the clear winner. No two ways about it in my opinion.
So, will go with Marantz NR1506. But, it has only 50W per channel. Will this limit my choice of speakers?
Denon 520 BT is an entry level AVR, so better to pair it with efficient speakers..Consider this speaker from Hifimart -
Will check them out. Thank You!
No doubt go with Marantz, instead of Micca look at Polk-Audio-110B looks like killer price :clapping: should pair perfectly
All right! I shall check them out.
How about this package, which is available on ebay India?
Is Denon SYS2020 5.1 speaker package, good for Marantz NR1506?
Seems, the center is as good as front and surrounds. Isn't the center to be little more prominent then the others?
Please advise!
Not at all. That rating is 20Hz-20kHz, at 8Ohms 2 channel drive. This is unlike other amps which provide 1Khz, 6Ohm, 1 channel driven ratings. This 50W is more than enough to drive most of the speakers with ease. 8Ohm bookshelves with around 88dB sensitivity or higer are not a problem at all.
MaSh
Took the plunge finally. Booked polk signature series s15 fronts, s35 centre and owm3 surrounds.
Paired with Yamaha HTR 3067.
Starting from basic 5.1 sub/sat systems went ultimately to proper bookshelves and center. Will post detailed audition and purchase experience later. Learned a lot in this forum.
Sent from my ONEPLUS A3003 using Tapatalk
Re: Mount for Pioneer SP-BS22-LR AJ?
I have closed in on "Pioneer SP-BS22-LR Andrew Jones Designed Bookshelf Loudspeakers" as my fronts. I would like to wall mount these speakers, BUT it does NOT have provision for mounts on the back and to top that has rear ports.
Is there anyways I can overcome this aspect of these speakers?
Are there any mounts which provides sufficient space from the wall and can hold these speakers?
Please advise!
https://www.amazon.com/Pioneer-SP-B...r=1-1&keywords=pioneer+andrew+jones+bookshelf
Re: Polk S15 and S35?
MRPs of s15 22.5k for pair, s35 27k, apply 10% discount, effective price 44.5 k
How is it going on with Polk fronts and center? Are you happy with the performance? :)
I got my Pioneer BS22 Bookshelves, this morning! They are huge! :indifferent14:
