Bose 2.1 CineMate GS
salil.bakshi
This is my first post on Hifivision. I have just ordered a Sony PS3 slim 320GB from Singapore. I already have a HD ready Panasonic 42" Plasma. The only thing remains are the speakers.My room is not very big, say 16ft by 14ft.
I visited Croma and Ezone in Mumbai.Among other's, they showed me Denon & Yamaha AVR's and some speakers to go with them. Frankly speaking I was not satisfied with them at all. Then I visited Bose showroom and was BLOWN away by their 2.1 CineMate GS Series 2 system. The sound just filled the whole room ( ofcourse, they have excellent acoustics in there). Even as compared to the non GS model this was WAY better.
So, my question is, is this system worth Rs. 50k+???
I would love to have the alternatives as it overshoots my budget by atleast 10k.
Salil
P.S. My usage will be 50% Music/TV & 50% PS3/Blue RAY/DVD
Absolutely not. Buy a pair of good bookshelves and a entry level reciver which will be better than cinemate. Well 3-2-1 or the V series is better than the cinemate which is pathetic
Hi dillihifi
I was under the impression that the difference b/w 3-2-1 & CineMate GS is that 3-2-1 comes with a DVD player. Am I wrong?
Salil
read the forum and it will take away your misconception about bose
Keep some budget ready and visit some real hi end shops and start interacting with forum .
I am sure you will get better solution than bose.
Hi hemantwaghe
Could you help me out with some shops I can visit near Andheri? It will be much appreciated.
Furthermore, I found on Ebay, Yamaha RX-V465 5.1 Ch Receiver | 1 Year Mfr Warranty for Rs.21,990/- ( 0% EMI options also available). Should I go with this or can I look for something cheaper too? Like Yamaha YHT-292?. If yes, could you suggest me which speakers should I go for? I think I can start with 2 speakers and keep adding as I go along. Say wat?
Salil
There are 3 shops at DN Nagar (2 or 3 mins distance from each other)
Viola , Alliance 4, The Shop
The Shop is slightly tricky to deal with. Thats my personal experience
Move a little ahead, say 15 mins from DN Nagar. Come to Janki Kutir, near Juhu Beach where Prithvi Theatre is situated you will come to Boomarang. They stock some real hi-end stuff. They also have budget offerings like Monitor Audio
Listen to speaker + amp combos at these shops. Short list the ones you like and then write about it on the forum for further help
Rikhv said all
Now AUDITION EVerywhere and check pries in Alfa
Check all my threads ,I gave pricin in some threads
I found yamaha 465 @ Rs 18000 in alfa also there was a missionpackage
