ardesarchitects
Hi ,everyone
I know Bose is big "no no" in audiophile world. Let me put my version, though i am not a pro audiophile but have a detail ear for quality sounds .
I would like to write my review on BOSE 520 that is not available anywhere in forums.
I purchased cinemate 520 for the very reason of flexibility to connect any player / setup box /gaming console up to 4 units HDMI on the bose console .
I decided on bose because i need a home theater set up in my mid size living room and then i cannot afford for large size speakers on floor or on walls.
Some how as an architect i feel filling room with huge speakers for best audio quality sounds crazy unless its a dedicated home theater room.
Pros
1. Unlike previous bose version this comes with a simple console ( it self is amp and audio conditioner) to connect our own players ( DVD,AUX,GAME console,TV,digital aux)
2. It is like a plug and play system
3. Speaker output is very clean and clear with zero noise .
4. No buzz sounds or electrical inferences though my audio wires were running in parallel to some electrical wires in ceiling
5. Universal remote literally makes your living room free from all kind of remotes
6. Wireless woofer that need power source ,so you can hide the woofer any where in the room with raw power access
7. Best suitable for converting any room in to home theater with out any acoustic panels ,false ceilings etc.
8. ADAPTiQ helps to automatically calibrate the speakers based on the location ,yes it works like gem .
9. Console automatically converts the audio to stereo and srs irrespective of source you are playing .
Cons
1. I wonder how BOSE missed the basics of speakers ,you cannot play HDMI music with out TV on ,yes you heard it correct .
Irrespective of HDMI source ( except RCA or AUX )you are playing ,the console goes mute the minute you switch off the TV .Bose version is that its a home theater first and then music system.
2. I find woofer is little compromised ,so for the people looking for high BASS would be disappointing.
3. HDMI CEC option is little confusing , BOSE starts dominating in controlling TV.You switch off TV automatically BOSE switches off.
4. As usual BOSE wall mount stands are very expensive and in this system you end up wasting the hanging bracket if you are fixing the speaker directly to wall .
Even only the wall bracket is same price as full kit
5. Wireless is optional to play music from your phone even after paying so much.
6. The console amplify & condition the audio digitally, there by adding some chilling effects to audio output that many amateur audiophiles like me may not like it.You can counter it by adjusting in equalizers.
Ar.Praveen.N
Ardes Architects & Interior Designers
https://www.facebook.com/ardes.architects
Pros
Cons
Ar.Praveen.N
