Boston Acoustics XS-Satellite as Rears
ankurjbl
pune
I have AJ BS22 as front and C22 as center with Marants 1504. I am planning to add BA XS as Rear. Pair is available at htstore.in for 5500Rs.
Can someone tell if these will blend with current setup ?
Any review for these as rears. living room is small 10 X 12 with opening from left.
BA XS tiny speakers should do the job as rears/surrounds. I too have been thinking in the same lines.
Better get clarified with Lokesh from HT store.
I used the BA XS with NR1402 and 1504...they will work just fine...unless you are looking for some bass thump from them...you may then want to consider bookshelf speakers...
BS 22 has good bass as of now.later I am planning to add good sub.
is 5500 for a pair of BA XS okay?
