Both Speakers working well and same how to check - any App to check ?
goget
New Delhi
HI All,
I wanted to check if both my speakers are working well and at same level - any App or method to check it .
Reason is since in shifting rooms -one floor standing speaker got dropped on the floor from a height of 4 ft.
Hope it is not damaged.
Use REW and check with a USB mic and check the freq response. A cheaper solution would be to download a set of test tones and play them and use an app like SPL meter from your listening position and check in both speakers - one at a time, if its at the same level.
