Thanks all!
I was in the lookout for a sub in 30k range and was keen to check out new BasX Series. Went to HT Store and only S12 was there in demo. S10 yet to come. It was connected to Denon AVR and we played few demo tracks. Fronts were Dali new series floorstanders. Overall we were happy when played few music tracks and movie parts.
Velodyne impact and Taga looked quite smaller units when placed near Bas X S12. The build quality of Emotiva was much superior.
S10 MRP is 32k, S12 is 39K. All the stock is expected only after GST billing.
I have bought the S12 for 33k with 3 yrs warranty. It was just unpacked for demo for a week. Front grill, manual all in fresh cover itself. So it is like brand new only with little breakin happened for a week. Did not want to pay more after the new billing rule. I found this price much reasonable for a 12inch 300W sub and took the subwoofer home !
I have connected the sub in my setup and the initial impression is just awesome !!!
This is the spec from the user manual
Amp : High efficiency class D
Power : 300Watts RMS
Frequency response: 25Hz - 200Hz ( +/-3db)
Inputs : LFE or summed left and right, unbalanced
Controls : Crossover, Phase, Volume
Dimensions: 17.25inch high x 16.75inches wide x 18.25 inches deep.
Weight : 22Kg ( 48.5 lbs )
The bass port is slot type on rear.
Build : The build quality is excellent compared to the other subs in this price bracket. The rear panel is simple with minimal control. Power mode switch has On, Auto and Off. Very heavy and size is huge.
RX-V477 subout is connected to S12 with bluerigger subwoofer cable.
Sub setting:
Placement: Placed infront of Front L. I don't have space on either side of L or R.
Volume : 50% ( 12'0 clock position)
Phase : 0
Crossover : Maximum ( LFE )
Ran YPAO and AVR set the parameters:
Sub : Use
Front : Large
Center : Small
Cross over : 100Hz
Sub level : +2.5db
Listened to few songs and I have changed the sub level to +5 db, Fronts to small keeping the sub volume 50% itself. Cross over kept at 100Hz ( Will experiment the recommened 80Hz ).
Music: After changing the level I had the feeling that diamond 220 has become so huge and the sound stage was too good. I couldn't make out the bass was from subwoofer, rather I felt the 2 bookshelf was playing with great bass. Played "Bass I love you basstronics" and it was just shaking everything with plenty of low end. Played few classical and malayalam songs with and it was really giving me that quality thump. These songs do not have very low frequency, but I think the mid bass output from the sub was really good. I am so happy the way it is doing for music so far. It wasn't localized bass or boomy at all. In fact the sub is more enjoyable in my living room with the above setting than in demo room. Wife has the same opinion.
Movies : Watched the Dark knight opening scene in blu ray. The real power and bass came in to play here. I have turned down the volume little.it was so good and we could really feel around us. Now I know how much I have been missing.
Initial feedback : It is a well built sub with excellent performance for movies and music. I had the feeling that 12inch sub may be too much for my living room. But I think i have made the right decision and even with lower volume levels it is working great in my setup.
This should be in the demo list If you are planning to buy sub below 50k range.
Congrats..
Nice review, I'm also happy user of S10 for an year, it's performance and build quialtiy are simply awesome
