can wharfedale 9.1 be wall mounted?
tinny9
Patiala
hello guys....
i am planning to buy wharfedale 9.1's to connect with yamaha 463.
i have two questions :
are these suitable for rear surround or better than wharfedale 9 SR?
please tell me the better one out of the two for surround.
i want to wall mount the surround speakers; can 9.1 be wall mounted, how?
thanks
hello guys....
thanks
9.1 realy not neede for surround as surround sounds not offen in movies.
Only in few sceens surr r active.So why to spend extra ?
If you realy want it,you can place them with special stand or support.
hello guys....
thanks
Dia 9 better matches with 9.2
hello guys....
thanks
SANUS SYSTEMS WMS5B Wall or Ceiling Speaker Mounts ( 5-pk)
or something similar should take care of mounting options.
for surrounds the SR would be better becuase they are dipole speakers and the surround channel is better dispersed.
There is no direct wall mount option, but you can always install a bracket-stand and place the 9.1s on them.
hello guys....
thanks
