Capacitor 10000uf 80v 35X50 mm
rdevarajan
Dear All
My power amp capacitors have gone bad. I am looking for 8 Capacitors 10000uf 80v 35X50 mm. Tried sourcing 8 from Ritchie street and they turned out to be duds and burnt down.
I am looking at loads of these in ebay but not sure which are genuine and lead time are long.
Gurus please help.
What is the specific application of these caps? I'm guessing PSU filter caps, but is it Class-A/B/AB or D?
What brand and rating were the burned caps? If they ratings were the same as the original and correctly installed with respect to polarity, they would probably not have burnt even if they were poor-quality brands.
You can look for the following brands in the order of desirability:
Nippon Chemi-con
ROE (Roederstein)
Epcos (Siemens)
Nichicon
Elna
Panasonic
Rubycon (check carefully, they're often counterfeit)
Toshin Kangyo (TK)
Sanyo (now Suncon)
Samxon
Samyoung
Samwha
Jamicon
Capxon
Keltron
