Center & Surrounds upgrade!
Yes, I would believe so. Try auditioning the Dali if possible along with your Sub.
MaSh
Damn and I always thought towers are way ahead then bookshelves lol. I think I need to concentrate on bookshelves and see how good they are tbh. Thank you
Book shelves like Dali zensor 1 better then these Yamaha towers?? [emoji15]
Buy the Zensor 1 and replace the 8390s, you will not need us to tell you the difference. Prudent advice from others, when you have a decent sub there is no need to go for FS, for 11x11 room Zensor 1s will suffice.
That's why auditioning is important for most of us. See if you can try to audition in a small room.
A square room is not good for sound. Do read up on setting up speakers in a square room.
Maybe some experienced FMs can also help.
My 2 cents, SVS are costly speakers, it is not really required to go for a SVS Prime speakers for surround as they hardly come in effect for 70 to 80% of the movie watching. Hence pumping your money to surrounds is the least choice one will make. As suggested by many, go for Dali Z1 for surrounds and save the rest for SVS Tower, then go for CC and FS at one time.
All great advice. Do consider the opinion of experts
It is best to upgrade the fronts, preferably all from the same family.
Bookshelf or towers is a personal opinion. For HT, the general opinion is that towers are not needed.
A beefier receiver is always better. It allows for great dynamic range in movies
Surrounds don't matter much. That must be your last worry
Thank you :)
