Centre Speaker
vsvasan
CHENNAI
I am looking to add Centre speaker in my set-up.Presently having the following
AV Receiver - Marantz SR 7008
Font : Tannoy Revolution DCT6 SE (Floor Standing Spekers) :
8 Ohms,Sensitivity : 90 dB,Frequency Response : 30HZ to 35 KH
Sub woofer : SVS : PB12 NSD
Kindly suggest suitable Centre Spekers.Budget : 40 K
You can go for the same series - Revolution DC4 LCR
Heard that,DC4LCR does not seem to be regarded as very good centre spaeker,compared with paradigm,PSB etc.,
Hence,would like to go for different make
If you are looking for other brands then I would advice you to request the dealer to provide one or 2 demo centre speakers to take home and see if the timber is matching with your tannoy. Remember the typical horizontal woofer/tweeter/woofer center design is a flawed concept (three-way center speakers that centrally position the midrange driver under the tweeter are better).
I have Shortlisted the following Centre Speakers
Paradigm CC 490
PSB Imagine C
Klipsch RC52II
any opinion on the above speakers or any other better suggestions
Marantz SR 7008,Tannoy DC6TSE,Rotel RA-12,Monitor Audio M6, SVS PB 12 NSD,Oppo BDP-95,Pioneer BDP LX-55,Marantz CD 6004, Optoma HD 20,Airtel DTH,Asus Mini O Play,Seagate HDD 2TB,Chord Crimson RCA,QED Optical & Audio Quest Type 4
