cheap 32" lcds under 18k
changappa
bangalore
moeser bear ,mitashi,sensui,and videocon, U may consider them as a bunch of 2nd grade tvs while comparing to sony,samsung etc. But they r giving a real fight to the so called biggies.:yahoo: its war out there visit some malls & show rooms u will know. Now videocon released a model hero 32" hbl fbt this is a hd ready model with hdmi port & pc connectivity. the looks r as good as the big fellows also the picture quality is good price is below18K also it has got a USB port. color is very natural & u can really adjust it to ur taste if u sit and fiddle the remote for 10 minutes. Check it out if u r looking for something really cheap. And if u hook up I ball Tarang 5.1 or even 2.1 u will have a good sound effect ( iball 5.1= 2K, 2.1 = 1.2k).
Toshiba range in 32 inches is very good.
They also have a HV series model around 17k. If you buy from Letsbuy you could get it cheaper by applying a discount code.
