This is my recent dac build, it uses low noise TPA7A47 reg for the power supply of both main dac and IV stage. It also uses a isolated i2c section for isolating the microcontroller from the main dac from any possible noise from the microcontroller.
Congratulations! Looking good. How does it flares with other similar range DACs?
What is the design based on? What is your DAC Chip?
What I can make out is USB I/p is based on cm6631A chip. Is that correct?
Beautiful build - the boards are all from Ebay I'm assuming? Would be very interested in details about the rest of the components - the case, knobs and that display! (and whats driving it)
Xmos asynchronous usb
Thanks for sharing these details - this is the dual mono implementation you had written about earlier? Any plans to do kits - what would such a build cost?Not from ebay, dac board is made by me. It uses arduino nano mcu. The enclosure is plastic. Front panel has mirror finish. The display has mirror finish, the display is visible when dac is powered. The knob is anodized aluminium sourced from ebay as you said. The display, enclosure, mcu are purchased from India. Dac board uses thin film resistors, film caps and low jitter low phase noise crystal all sourced from digikey. Dac ic is sourced from singapore. Making cost is quite high as i had to pay customs duty for the imported parts. Some parts i already had.
There is group buy for ESS9018 based DAC,started by Member from India-You are the man!! Boared with my Dac Magic, I am also planning to build a ESS9018 based DAC...
LOW COST ES9018 DAC BOARD GB - diyAudio
Also-
http://www.audiodesine.com/ES9018_HD_DAC_MODULE/p2022996_9891573.aspx
http://www.audiodesignguide.com/DAC32/
