Commercial/PA/Studio amplifier as home amplifier
hemantwaghe
Banned
Banned
Hi All,
As my activity on this forum shows that I am partially baked ( not even half - lesser) :D;) audio enthu.
Now my question is
How suitable a Installation - Studio amp is good for home use
I am referring Inter-M R-500 Referance Amplifier.
There are chances that demo piece I'll get for cheap
I am attaching it's manual.
Now it is Inter-M Korean brand I never heard.
What I find that this powe amp has impressive powerr specs
Stereo 8?, 1kHz (per channel)- 170W
Stereo 4?, 1kHz (per channel)- 250W
Bridged Mono 8?, 1kHz500W
Frequency Response ( 0.5dB)
also it's manual describes -
High Performance Monitor Amp
Studio quality monitor amp provides clean sound for the studio, conference room, concert hall and commercial installations.
I'll get only a brief audition
Now my questions are
1) Worth buying at 7.5-8.5 K?
2) Any forum member's expereinces?
3) Any expereinces of the brand Inter-M
I'll be using either Pulz pre or sansui reote controlled equalizer as pre ( It has volume control ansd source attachments)
Speakers will be Solid ( another brand of B&W) Sat- Sub & I am planning floorstanders
Source 1) Pioneer 100 CD Changer 2) Teac CD Player 3) i Pod
SO YOUR VIEWS EXPECTED BUDDIES!!!
Thanks in advance,
Hemant
i used a yamaha p2000s pro power amp on my setup initially. used it with a) yamaha mixer and b) nad pre amp. it had the power but apart from that nothing. didnt have the range and was muddy throughout, wasnt musical at all, bass was flabby. i wouldnt recommend a pro amp for home use
