Dear all....
I learned a lesson with big boxes in my small room ....
As some of you know, I made a center channel with 12" FR, SK12FRX
This driver needs a large box for getting better low end extension.
I want to get rid of large box, and build a compact center channel.
Center channel with SK12FRX Ahuja has the following advantages.
8 Ohms impedance & High sensitivity(easy for any basic AVR to drive)
Obviously vocals are pretty good.
It can go loud if needed (but feels a bit shouty).
Price is very affordable & easily available.
Now I am looking for a small FR driver that can perform better than Sk12FRX.
My preference for center channels is....
Sounds like "male vocals" or "a lions roar" or a "dinosaur Snarls" etc should sound dynamic and authoritative.
Ahuja does this job nicely @ its price.
Is there any 4" or 6" or 8" ... (the smaller the better) driver available that can fulfill my requirement?
I am ok to use multiple small drivers, but the final impedance should be 6 to 8 ohms... and high sensitivity and high Spl is preferred.
As far as possible... I need a "not very expensive" driver, and it should be available in India.
Any leads or suggestions or ideas please ....
