compact subwoofer for beat
kaustubh
Current setup:
Beat LT OEM HU - seems to be pretty neat
front(4" coax), back(6" X 4" coax) - boston audio (both in stock locations)
Budget - 8k (max 10k)
Looking through the other posts I see that most would recommend a 2 ch amp (sony, blau for 3k) or a 4ch (blau gt4 mk2 ,kenwood 8401 for 5k).
I want it to be as small as possible in the boot (don't think underseat is possible in the beat)
Don't want it to thump too much or go too low either, just enough to complement the small coax's i have will be fine. An 8" or 10" would be enough.
Looking for good sub suggestions that require a small enclosure size in the 3k range.
Also, any suggestions for compact enclosures and how much they would cost getting done in bangalore.
Polk Audio has one compact subwoofer.
I got one myself. It cost you around 4500 with enclosure.
images
It will suit Beat.
And get some Monoblock AMP to drive SUB. will cost you sround 3-4 k max.
