Confused on speaker purchase
deonddj
Kerala
I sold my current polk system (s50, s35, s10s hts 10 rc 60 with denon 2800h) for 1.3 lakhs
Now im looking to buy tower speakers under 1.3 lakhs to use with my denon 3800h.
Please suggest good tower speakers that are good for both movies and music. I looked into monitor audio bronze 500s and q acoustics 5040i, any other suggestions are welcome. Thanks😁
There are brands like Fyne audio, Dali Oberon and PSB too.
Elac debuts 3.0 are getting great reviews.
There is wharfedale 12 diamonds as well.
Also polk signatures
I always say, get a demo
Very limited demo options here in kerala. I heard the demo for elac debut 3.0 series liked them too. Also looking at polk r700, revel f36
But ive heard theyre more focused on music than cinema, but have heard very good reviews about the dalis. Also maybe revel f36 or polk r700?
if its great for music, it will be great for movies as well
fyne audio has a 2.5 way center speaker with coaxial design, just like kefs. these speakers have wide dispersion compared to normal mtm design.
for movie, you need a subwoofer, that's what makes movies fun
Yes will get dual rhythmik or ascendo subs in a few months. Are you talking about the dali speakers here?
Will look into the dalis too then, maybe the oberon 7, 9 maybe out of my budget, also the center channel is a big deciding factor for me, for example if i get bronze 500 towers, i plan to go with silver 250 3 way center channels.
If you have heard and like the Elac then they are good too.
I am using Dali Oberon1's with a subwoofer due to space constraints. They are decent for both movies and music . But pls take a demo if possible before buying any speaker brand to see if it caters to your tastes.
Pls take a look in the HFV classifieds section too if you are open to preowned speakers in good condition.
Sure will try to😃, also have to get the acoustics correct
If you plan to use speakers directly with AVR then look for efficiency such as klipsch. If you are using external power amps then a lot of options open up.
I plan to use my towers with the avr for 2 months after which i will be setting up a dedicated home theatre room 7.2.4, will add atleast 7 channel amplifiers to it
