Connecting LSR305 to Xonar DG sound card.
Tom Cyriac
Kerala
I bought a JBL LSR 305 and is confused about the best way to connect it with my soundcard. I have a 3.5mm speaker cable with me. So will a simple 6.35 to 3.5 mm adaptor be enough or do i need to get a 1/8 to 1/4 cable?
I would also like your opinion on whether i should get a DAC to remove any hissing problem.
