silentsound
Is it ok to connect the front L/R pre-out from the AVR to one of the input in the stereo pre-amp? I'm trying to use the same set of speakers for music and movies. As per the AVR spec, the pre-out is 1.0V/500 ohms and the pre-amp spec says maximum input impedance is 47k/200pF and max input signal is 10V.
Thanks,
SilentSound.
Thanks,
SilentSound.
