corner wall mount for TV
laddankailu
Hi All,
I am buying a 42'' plasma and plan to wall mount it.
The challenge is that the factory default wall mount can only be fixed on a flat wall and I want my tv to be installed in the corner of the room.
I serched through the forum and read some older posts suggesting corner wall mounts from vangaurd and omni. The price of these is varying between 6K and 15K.
Firstly is my info on the price correct? If yes then Would appreciate if any one can share a cheaper solution.
CD
I am sorry, bought this a long time ago so dont remember the price or the model number (not mentioned on mount either). Im sure you can get some info from them directly.
