Customised system for my clinic
dr.jigar
India
Hello everyone,
I am a dentist , and I am opening a new clinic in bombay. 250 sq.ft carpet area. will be divided into 4 zones approx 60. sqft each(1.reception and waiting room, 2. consulting room, 3. operatory 1, 4.operatory 2). I want to put up speakears in each zone and have individual volume control in the same. running on tight budget approx. 20-25k. any suggestions?I will be playing country, soft rock, retro, old hindi, blues and a few hip-hop.
(would prefer wall mounted speakers rather than ceiling)
Thanks a lot in advance,
Dr.Jigar.
should i go for the speakers of the same company as the amps, and how much would they set me back by?
Speakers with same company is prferred.DNM has exact solution which you are looking at.Norge amps are better than DNM though-
DNM ENTERPRISE
211-D, ANSA INDUSTRIAL ESTATE,
SAKI VIHAR ROAD, ANDHERI (E), MUMBAI 400072
TEL. NO. 022-28474799 TELEFAX NO.: 022-28474038
MOB: 98200 64528 ( DILIP BAJAJ)
thanks a lot for your help spirovious will check both of them out and keep you posted , and by the way do you have any ideas about ceiling mounts for monitors/tv........
