Dali zensor 1 vs elac5 vs Qacoustics2020i
Wonder
india
Dear forum member,
Happy new year to all, i want to know which one is best of these Dali zensor 1 vs elacB5 vs Qacoustics2020i? I cant decide to select one of them. Could you please help me out? Where i can get good price on them? Please provide contact numbers.
Thanks in Advance,
wonder
Which AMP are you planning to use?
Do you already have AMP/AVR or planning to decide after speakers?
Z1 are impressive and VFM.
@ wonder
which location are you based? Then only FMs can share contacts and also recommend some places where you can audition and decide for yourself.
@ wonder
Am located in andhrapradesh, audition is not possible here in my home town.
So please help me out ,which one is the best of them and good price available places and contact numbers please.
Thanks in Advance
wonder
Thanks in Advance
wonder
What's would be the purpose of these speakers? Stereo music listening or home theatre? Elac are good but need a beefier amp to really make sound really good. QA are very airy with very clear highs and mids, lacking just a bit in the low end. Dali comparatively are a more complete speakers.
My vote goes for the dalis.
MaSh
Sent from my Redmi Note 3
Thank you so much...Is z1 suitable to any av receiver? Please help me out.
It seems to me that your are building stereo (2-Channel) setup and primary use will be music, of course you can enjoy movies too but not surround sound formats like DD, DTS, etc.
First of all, Dali Z1 are excellent small bookshelf speakers, can be used in stereo as well as home theatre setup at different channel position depending on personal preference.
To pair with, you need either stereo amplifier or AV receiver.
If you are quite certain about MUSIC and wants nothing but holistic musical setup then nothing is better than stereo setup, and you should go for stereo amplifier. I like sound signature of Marantz with Zali, nice and balanced setup.
Speakers = approx. 21K
Pm5005 = approx. 27K
Cables and interconnects = 1 to 2 K
Here is another aspect, if you enjoy movies as well then AV receiver is another option for you. You can setup 5.1 (or more) HT setup later if you look to use AVR. Some find music (stereo) output quite close to dedicated stereo from AVRs but its highly subjective and depends on your taste and listening.
The point is AVR can give you more value for your money, if you are not so critical and sensitive music listener.
More than any other suggestion, most critical is to experience yourself the sound of the setup. Do audition.
All the best :)
My setup is for movies only than music. First will buy bookshelfs and center.... later will add remaining surround channels and subwoofer. If i buy dali z1 pair for left right and vocal for center( or any other center suitable ) and let me which surrounds should be suitable for this setup....thanks in advance
If you have decided to go for Dali, then I would strongly suggest you look at Z3 if budget permits.... I am sure you wont regret for those extra bucks spent.
If primarily for movies, look at polk rti a1 too. Polks go well with denon / marantz receivers.
MaSh
What would be the cost of z1 and z3? could you please share some contact numbers of the dealers to get more discount. Thanks in advance.
Check HT Store and other online reputed dealers,
ProFX deals with Polks and you can try a good deal for RTiA1s or A3s.....they also sell Denon and Yamaha AVRs.....
Dalis have a good reputation world wide and hardly heard anything bad about them....
Perhaps a few YouTube videos will help to give some idea around performance.
Hello guys am new to this forum. Am planning to buy my first bookshelf speakers . where can I buy dali zensor 1/3 n elac debut b6 for the best price in Hyderabad?
I have not heard q acoustics, but between zensor and elac, I will definitely go for zensor 1. Zensor 1 are VFM speakers which will suit both for movies and music. If u r concerned about movies only you can check Polk rti series speakers also.
In case of zensor 1 you will not regret it. The same will be good for surrounds too. If you more budget, go for zensor 3 as fronts and zensor 1 as surrounds. Good luck.
Sent from my ONEPLUS A3003 using Tapatalk
Dear forum member,
Thanks in Advance,
wonder
what you finally purchased?pls post ur review here
Overall
Qacoustics 2020i are ok for music and decent for movies
RTi A1 / 3 series of Polks.....I would say 50 50 for music and movies...
Dali Zensor 1 - placement specific speakers.....very good for music....no sub required at all.....at my moms place.....movies....decent job...
Audition NHT Superzeros and NHT Superones. Nht is known for it's high end audio Speakers. Both are entry level models, fantastic for stereo listening. They are very musical, have wider soundstage great mids and crisp highs.
Are Acoustics suspension type with sealed box. Very wel known in Americas since decades.
