I am Intrested in FS for front/Centre & BS for Rear surround & subwoofer for the same.My use will be Music & Movies both 50%.Avr Will be Denon X-1000.
My Bedroom size 15' by 12'.My Budget is Rs.1 lakh Maximum.
I have been advice for Following Speakers pkg:-
Dali Zensor Series 5 (Full 5.1 pkg 5 Star rated by Whathifi for 2012)
A)Dali Zensor 5 - Two FS For Front.=42,000/- per pair.
B)Dali vocal centre-= Rs. 18,000/-
C)Dali Zensor 1 -Two BS (Again Award Winner) for surround.=Rs.19,000/-Pair
D)Dali Subwoofer E 12F- 1 no.=Rs. 45,000/-( expensive).
Total MRP of pkg is Rs.1,24,000/-(after Discount Rs 1,10,000).
If I sellect Zensor 7 for Front than there will be Rs. 10,000/- more.
Monitor Audio MR 4 Series pkg.
A)FS MR 4 Pair (Rated 5 star by AV Max in current August 2013 edition)
Rs.29,000/- Pair.
B)MR centre Rs.11,000/-
C)Subwoofer MR 10 Rs. 27,000/-. or Sunfire 8'' Rs 38,000/-.
D) MR-2 Surround BS Pair Rs.17000/- or Vector Series Rs. 18,000.
Total For pkg is between Rs.80,000 to Rs.90,000/-.
Unable to Find Paradigm 7 price.
This are the pkg which i recieived.
which is best out of this two? OR any other best Speaker suggestion?
Are they worth for price and quality performance?
I am open to all kind of your expert advice & Suggestion/guidence..
Also Any Suggestin For Whorfdale Diamond/Jamo/sonodyne/pioneer/kef ?
After working for last two weeks on this,My Budget already went up double from Rs.50,000 to Rs.1 lakh...So, I am little confused and unable to Find proper Solution for my 5.1 Setup.
I request you all.... please help me in finding proper Setup....
Thanking you...
Rajubhai
Rs.29,000/- Pair.
Thanking you...
Rajubhai
