Haren Asher
Hey!
Need help with the Denon 1611 setup.
I have connected the TV in the ARC hdmi in of the Amp. The Samsung LED32D550PRMXL is ARC compatible, and the hdmi cable is a 1.4 version with ARC capability.
Also connected Tata Sky HD, and Pioneer DVD 220K to the Amp via hdmi.
Am able to watch Tatasky and DVD through the Denon.
My problem is that my TV is a pretty good media player. Since i have a whole lot of movies all torrented. And normally all of them are BRRips filesize varying from 1.5 to 4gb. The TV can play mkv, avi, mp4, mpeg,divx, etc.
when i plug in the usb HDD to the tv, and play, i get only video and no audio. If the TV /Cable and Amp are ARC capable, shouldnt it play all audio through the Qacoustics? .
If not, then what to i need to do to get the Denon to play all of TV audio through the amp? .. Will buying and optic cable and connecting the TV and Amp with it help?
I did succeed in connecting a cable with, component L+R on one end and a 3.5mm jack on the other, to the Headphone out and got the Qs to play the TV audio. However, the audio is now controlled by TV (logically correct) and not the Amp.
Basically how do i get the Amp to process all sounds from the tv? ..
Thanks in advance for viewing, understanding and hopefully replying
Cheers!
Cheers!
