DENON 1910 HDMI output stopped working
sreenathplus
Madurai
I would appreciate your help ; DENON 1910 HDMI output stopped working (while trying to connect with H96 pro+). Checked with Denon service center (Hyderabad) they said as it is old model we may not able to replace the HDMI board.
Can anyone help me on the same or any workable solution. Thanks in advance
I had the same situation with my amp. So, I have started using it like this.
For audio, optical out from my HD setup box to amp
For video, HDMI on setup box to TV.
For Dolby digital, It will be sufficient. For Master DTS or above 1.5 Mbps transfer, HDMI is must.
Other knowledge FMs would through some light on that if you need help on this subject.
Sent from my Lenovo K50a40 using Tapatalk
I had an Onkyo 818 AVR, with similar issue, replaced the HDMI board.. But nothing worked..Even the digital inputs..
If the issue is with HDMI board, then better not to replace .. As other FM suggested, check if the digital inputs work..
