Denon 791/1911 display issue
madhurvyas
Bikaner
I have been using denon 791 which is similar to 1911 for last three years, last few days back it started giving me some problems, display on tv will go off after 15-20 mins, sound will still come, though when display goes off avr will pause for a second, then sound starts back but no display.
I'm using a htpc connected to avr which is connected to 42in plasma. Setup was working fine, havent done any changes to setup.
I tried connecting Ps3 to avr still same issue after 15-20 mins no display.
I feel either its heating issue, but its been running in same setup for very long.
Second though would be some internal IC has damaged.
Im too facing this issue with my denon x500 but it used to happen earlier now just the screen flickers once but there is no audio drop. Im blaming my hdmi cables currently as they are not very good ones just brought locally. Will try connecting directly and see if there is any issue.
My cables are from DAC, and are pretty good. I also feel some component is damaged, or go for dual hdmi graphic card option, one for audio to avr other for display to tv. I dont have any denon repair guy nearby, probably I have to go to delhi.
