sudhirbhosale
I bought Denon TU-280 tuner. I noticed that it is giving bit less bass (also same in mentioned in some review). It may be by design. FM reception is also weak in my area. Would like to know, if there is any way to overcome this. i.e. by doing something with input impedance.
Same time I amtrying to get NAD 4020. Since all NAD product bass is always great, I assume that same would get from tuner
not sure but just guess ...
So replacing TU-280 with NAD - would be a right decision? Can I get some model names which I can try hunting.
