Denon X500
alekhp
Calicut
I need an advise on this....
Can I use Sonodyne Genie 2 C Centre Channel Loudspeaker (Per piece, Black finish) with Denon X500 AVR...
Kindly Suggest some good quality speakers for this AVR
You can safely use the sonodyne speakers with Denon x500, they are rated at 8 ohm, 89db sensitive.
Denon x500 is not a very strong amplifier so you need high sensitivity on your speakers. 89db is pretty good
