D
Deleted member 15865
Guest
I experientially realised today that Dhrupad music, particularly when the aalap at the start of the performance, is excellent media to set the imaging of your speakers, even better than spoken voice. Reason being it’s just one singer (usually) with just a drone in the background and the notes are highly focused and extended. The control of a quality dhrupad singer on the notes is next to none. And the sound comes like a piercing arrow from one point - that focused. The singer usually moves across frequency range between notes so you can check imaging on the upper as well as lower registers. Of course the recording itself should have the vocal right in the center.
(One couid even try with the aalap in khyal recordings but it tends to float unlike that in dhrupad)
