diffusers for ceiling?
manu4panjab
in my house..,
hey brothers
can i use diffusers for ceiling or absorption panel or acoustic ceiling tiles or mixture of both diffusers and absorption panel
my room height is 10 feet
can i use thermocoal as a diffusers and can i paint it in various colours if i use it for ceiling and my back wall
please reply
Manu,
You can use any of the above-mentioned methods as long as you are avoiding reflections. The same applies for ceilings or any other wall.
It is a general belief that diffusion is better for listening rooms(two channel) rather than in Home Theaters (multi-channel)
Google and do some reading on diffusion. Also have a look at this listening room treated mostly with diffusers - ceiling, sides and rear. Absorption has been used, but very little:
Rives Audio Examples
Manu,
In the thread below, you'll find some interesting ceiling options:
http://www.hifivision.com/av-enhancers-room-acoustics/2979-please-suggest-false-ceiling-option.html
In my Home Theatre, I am trying to do a combination of diffusion and absorption. It is called Binary Amplitude Diffusor. I have posted some information and pictures in the above-mentioned thread. You will also find some information about how I am doing it in my Home Theatre Build thread below:
http://www.hifivision.com/av-enhanc...theatre-room-please-guide-me-8.html#post70468
If you are not in a hurry, please wait until I complete my Home Theatre (2 weeks), I shall post my experience on the False Ceiling Thread.
Manu,
brother i'm not in a hurry at all,i'm waiting for your reply :)
Manu,
and also please tell me how much you spend on acoustic treatment
can i use armstrong tiles for my ceiling is it best or not
and how much does it cost in black colour
please reply if someone uses it
Manu;
Armstrong is a good but expensive option. You may go for model "Optra" by armstrong. Its costs around rs.100/sqft including installation.
Vinay, has used armstrong tiles for his HT ceiling.
Cheers!!
Manu;
Cheers!!
thanks yaar :)
do you have any contact no. for optra
hey santhol bro
waiting for your reply brother
Sorry Mate, I missed replying to your question.
For my room of size 15ftx12ft with 8ft height, I have spent roughly around 1.25 lakhs including labour. This includes some fancy interiors, wooden frames, anutone boards, fibreglass and fabric. If I had not done sound-proofing, then treating only the reflection points would have costed me only half as much. Hope this helps:)
