Is it feasible to completely ditch DTH and rely solely on internet for a typical household?
I mean I have a 4 bedroom flat and there are 4 members in my family. I have N300 routers and extenders. Every family members wants and expects to use internet(watch/listen media, browse or game etc) at his/her own convenience.
So my query is that what should be the required bandwidth for peak load for
a. internet connection
b. throughput of the network.
if each member is watching 4k HDR content and as I read that 25mbps is recommended for 4k on Netflix then it would mean a minimum of 100mbps. Besides there are a lot of connected gadgets making demand on the network like CCTVs, downloading content, mobiles etc. So I assume that 200mbps internet connection is a minimum requirement. If we assume that all this is being done through wired ethernet connections then can a typical 300mbps N router handle this much load? Or do we have to use more than one router/switch(connected wired to main internet modem/router) to distribute this load? Or will N600 or AC routers perform better in such situation?
On the other hand if wired ethernet connections are not possible then can the problem of internet speed be solved by selecting a higher Mbps plan. I mean if 200mbps plan is required for wired situation then will say 400mbps plan be ok for using wifi network.
I am asking all this because it is impossible for me to get wired connections to each of my rooms and my only option is to use wifi.
I think that this must be true for almost every home as nobody wants open cables running around the house.
So can AC routers and extenders serve my home as outlined at the start of this post. I think then only can we ditch DTH.
