DIY Acrylic Platter Mat
jls001
Anyone's tried acrylic mat on their TT?
I've been spending too much time on soundfountain.com:lol: and was inspired to DIY an acrylic mat. I have only tried rubber mats so I was curious to hear the improvements claimed for acrylic.
So I asked a colleague to quickly draw a 280 mm diameter circle with another smaller circle in the middle for the spindle (7.25 mm diameter), in Corel Draw.
I already had 2 mm thick transparent acrylic sheet lying unused at home.
Got two cut from a local laser guy who specialises in cutting acrylic sheets and thin (upto 8 mm ) wood or mdf sheets. It was a pleasure to watch for the first time the laser machine at work. The cut turned out to be perfect, absolutely clean cut, and no need to polish off burrs. It looks like it is already polished.
Since 2 mm is too thin, I glued two layers together.
Target thickness - 4 mm. Achieved 4.19 mm (I measured with a digital vernier scale).
Target weight is 400 to 430 grams. I don't have a scale to measure beyond 200 grams.
Thickness of existing rubber mat of the Lenco L75 - 4.11 mm.
Sound: immediate impressions are -
1) better focus throughout the audio band
2) bass is lesser but easier to follow - I guess one could say bass is less muddy.
Lessons learned:
1) chloroform, the chemical used as anaesthesia is the chemical used to glue acrylic. It sets almost instantly, like super glue.
2) one sheet of 4 mm is less work than gluing two x 2 mm.
3) frosted acrylic is probably better suited for this application as it is more likely to hide scratches. Of course acrylic comes in many colours so one can get adventurous.
4) if I were to make another one I will make it 290 mm diameter instead of 280. But 280 will work fine for turntables with smaller diameter platter (like ProJect Debut III or Technics SL 23).
Will post pictures tomorrow.
Here's the link that inspired : Turntable Mat: Shape, Material, Damping, Sound Characteristics, Platter.
Some pics:
1) the laser machine at work.
2) here's the cut mat, protective paper peeled from one side in preparation for gluing with the other mat. One side is left unpeeled
3) on the TT. Note bottom side protective paper is left unpeeled as it provides better mating to the aluminium platter below. Note also the three largish blotches - these are where chloroform "glue" is poured (it has the consistency of water) and the second layer is promptly stuck before it evaporates and dries up. (please excuse the poor photo below).
Looks like an improved ver 2 is inevitable:lol:
Version 2 completed and spinning now.
Dia increased to 290 mm, single layer of 4 mm, lightly frosted instead of transparent.
If anyone's interested in brewing/rolling your own, PM me for the .cdr file that you give to your favourite laser-wala. Even without the drawing, it is simple - ask them to draw a circle of height 290 mm and width 290 mm, with the inner circle for spindle being W: 7.25 mm, H: 7.25 mm.
4 mm thickness is near ideal for me as it closely matches the Lenco L75 mat (4.11 mm). Your mat's thickness may be different. Some mats I measured:
1) Technics SL 23 about 5.5 mm
2) another one (whose provenance I don't know) is 3.5 mm
3) Pioneer PL 200 about 2.32 mm
4) Thorens TD 124 Mark I : 3.15 mm
So the thickness depends on what mat you want to replace.
Joshua, what are the sonic differences between V.1 & V.2?
OT, but does anyone know where we can source silicone gel sheets in India in small quantities?
Didn't sit down yet to compare. Been too busy today polishing my new aluminium cabinet (fourth and final grit before it goes off for a fancy, coloured anodising), and reducing the thickness of my tonearm (wooden) board and doing a wild oil polish (with olive oil!!!). I need to work further on the thickness of the arm board.
Joshua,
I am also anxiously waiting for your report with the new acrylic mat. If the mat is smooth, will there not be a problem ?
Joshua,
The current mat is used bare. No more protective paper layer at the bottom (which comes with the acrylic sheet). Just to test if it would slip, I switched on the turntable with the acrylic mat on it and poked on the mat with a finger to try and get it to slip. It refused to slip even when more force is applied. Though soundfountain.com recommends using a thin double-sided sticky tape to stick the mat to the platter, I haven't used it, but I think one should use it.
I am guessing it doesn't slip because of some part of the friction seems to be due to the the friction between the mat (matte finished frosted acrylic) and the platter and some part due to the friction with the spindle. Just to be safe, I use a center weight (whenever I remember) so that the mat will not slip. May be one can use URSR ring too as that also puts weight on the record.
One negative - it seems to accentuate surface noise, especially at the beginning of the first track.
The improvements I have observed are tighter bass (most obvious) and better overall focus (not immediately obvious) in the music. For the low spend, it is worthy upgrade.
