DIY Gainclone for PC usage
kaushik
Here is a gainclone for pc usage
circuit does not focus miracles in SQ but it is easy to use and
mix well with PC .
-small size with regulated fan cooling
-small easy to fabricate cabinet,if u find difficult grab local AMP ..in bangalore i see amps with AL(soso quality) front in 350Rs,rip off parts ,use the cabby with this GC
-Uses CPU heatsinks ..no need of bigger HS
you need to add silent Fan
-it switches on only when when PC is booted !
-simple USB input is there ,analog in will be better i guess from a good source
Link : A Gainclone for the PC Age
