DIY Subwoofer
crisscross
Hyderabad
Hey guys,
I got the Titanic MK-III and the Bash 300w Amp. I need to build an enclosure for it and have no clue how to do it. Can you guys help me with measuring the cu feet or point me to a guide? I will be using a carpenter in Hyderabad and if you guys can recommend someone that would be great.
Do any carpenters work with clamps in India? thanks for your help.
Length X Breadth X Height in ft will give you Cubic Feet. Take the inside dimensions for getting the right volume.
Check on the net, there is lot of help.
I know many carpenters use clamps
Cheers.
