Mayank Shah
Please share your experiences with Dynaudio speakers (Emit M20) with NAD 356 amp. Thanks.
Thanks. I thought NAD went from Britain to Denmark to Canada, but looks like you still got some British beef with NAD....Sounds absolutely terrible. Look for a better more neutral amp. NAD has the usual low end British equipment bass bloat.
Haha their sound hasn't changed much over the years though.Thanks. I thought NAD went from Britain to Denmark to Canada, but looks like you still got some British beef with NAD.....
Look for a New/Used Masterclass NAD integrated . Then it would be a completely different game
Add Parasound to this list, if you can audition their offerings.Thanks to all. But considering my budget of around 50K, I am looking at:-
1) Yamaha RN 602 - All in one convenience for the new generation
2) Yamaha AS 500 - Used, as the product is discontinued AFAIK
3) Rega Brio - New or used (As I have heard the Emit 20 with Rega Elicit)
4) Audiolab 6000A - Touch above budget
5) Rotel 1552 power amp - Used.
Sorry, not this model of Dynaaudio. Have you heard them or have any experience with them? They are very easy to run in fact. The older models and the higher series are a lil power hungry. These are the start of the Dyn's range.Dynaudio is a power hungry speaker and is well matched with Luxman and Audio Research Amps
I do have the 356 which I could not check with the M20 yet. The 356 will handle them with ease. Pricing of both the Yamaha's are much below my budget. (Hope to get some feedback on that combo). Rega brio and the 6000A are a touch above for new. If the 356 works well then problem solved.The pricing for these are much higher.FYI If you google there are reviews with the new 368,388 NAD amps with dynaudio spkrs.
Any contacts for Parasound in India?Add Parasound to this list, if you can audition their offerings.
As a recent owner of their pre+pwr combo, they do many things right at very reasonable price point.
Raghu
| India | Audio Excellence | 91 22 65010877 | [email protected] | audioexcellenceindia.com/home.php |
