Earphone with PC Mic
nc_hwr
Pune
Can someone suggest a good earphone with Mic (compatible with PC) within 5k budget. Idea is to listen music and occasionally calls can be taken from windows laptop when required.
How about Klipsch ProMedia ?
Thanks,
Nc_hwr
Unfortunately did not get any reply on this post. Anyways, few days back I got my Klipsch ProMedia. Sharing its pic.
Regarding this new pair which replaced my old Philips SHE model, highs are quite crisp & clear, I think thats typical Klipsch. Bass is punchy. Philips got a good boom sound. I would prefer Philips for bass, its personal choice.
For those who are looking for earphone with Mic. Most of the mid/high range earphones with Mic are built for smartphones which got a single jack. It's mic doesn't work with PC, only speaker works. For mic to work, you need a Y PC splitter, which at the moment cost around Rs 1000. (dont know why so costly). ProMedia works fine with PC and smartphone (tested with Samsung). For this purpose, I found Razer Moray+ as another option.
Hope this helps.
nc_hwr
