Energy Take 5 or Klipsch Quintet IV
roxy
india
Hello,
If you guys can help me out in selecting the speakers for setting up the home theater. As of now I am looking for 5.0 setup probably with satellites coz its small.
I am getting Energy Take 5 for 150$ and klipsch quintet IV for 220$
If you guys can suggest me which one should I consider from the above mentioned or If you have something else to suggest.
Thanks,
Roxy.
On my research I found out that both the systems are inadequate if your room is above 100-120 sqft. Even I am on my way to get a nice system.
Polk TL250 is a smaller one like Takes, but I like the sound. But again it might be small for a bigger room.
Look at Martin Logan MLT-2, the satellites have 4.5" drivers. You should be able to demo them in Magnolia stores. These would go well in bigger rooms.
Thanks for the reply.
Well do you have any idea approx how much does mlt-2 will cost?
Thanks,
Roxy.
