fiio k5 pro DAC as a preamplifier for Power amplifier
srijith
Thane
Hello Guys,
Kindly advice me if i can go ahead and purchase this DAC . i will be using it as a preamplifier for my poweramp which i will be going to buy
The specs are in the following link
The specs says Line out ar 2vrms. Will that be enough? is it fixed or variable not able to understand.
OUTPUT LEVEL2Vrms (1kHz/10kΩ)
Awaiting your advice.
regards,
Sree
It is quite a versatile gear in a small footprint.
You can use it preamp to connect to power amplifer.
It has enough drive to push your amp.
Yes got Arylic S50 Pro from Diyaudiocart, which they have confirmed has 6 months warranty
